Flow designer unable to see flow execution
SNow35
Giga Guru
I am trying to create some flows and tried to test via flow designer but when I click on 'Your test has finished running. View the subflow execution details' . I am getting screen as attached but  I need to see the execution details. I have tried to change the properties 'Level of reporting data generated by the flow engine' to 'all configurations and run time values' but getting same screen when checking execution details. Currently I have tried in washington instance.
3 ACCEPTED SOLUTIONS
Mark Roethof
Hi there,
Follow what @Zach Koch mentioned. If that's not the issue: update the Store application for "Workflow Studio".
Navigate to Plugins and Search for Workflow Studio:
And the Update it or schedule it:
11 REPLIES 11
Thanks very much @Mark Roethof. This fixed the problem for me.
I'm new to ServiceNow and I'm currently doing the "New to ServiceNow" training, which I started last week. My developer instance did not include this update, which made the "Using Flow Designer" module quite confusing. Can this update be added to new instances?
Regards, Scott
@Mark Roethof, my apologies. I just checked your profile and it doesn't appear you are a ServiceNow staff member. Disregard my "ask" about getting dev instances updated.
-Scott
