How bidirectional integration between ServiceNow and Jira works without using flow
Hafeeza_Shaik
Can someone provide an overview of how a bidirectional integration between ServiceNow and Jira works without using flows, instead leveraging spokes, APIs, and REST messages?
Ankur Bawiskar
@Hafeeza_Shaik
see these links
Jira Integration with ServiceNow using Webhook
Jira to ServiceNow integration Scripted REST API Jira WebHook
Ankur Bawiskar
@Hafeeza_Shaik
JIRA to ServiceNow usually is done using paid spoke.
if not spoke then you need to develop custom outbound and inbound integrations with JIRA
It all depends on what your customer requires.
Can you provide a brief description of how the configuration is done in Jira to maintain parallel data synchronization across both instances?
Ankur Bawiskar
@Hafeeza_Shaik
see these links
Vishal36
Mega Guru
Hi @Hafeeza_Shaik,
This comes up pretty often when teams want ServiceNow and Jira talking to each other, but without relying on Flow Designer or low-code flows. A few things to keep in mind when you’re thinking about a bi-directional setup using spokes, APIs, and REST messages:
  • Mapping logic lives in scripts: Without flows, you’re usually relying on scripted REST messages and business rules to map incidents, tasks, or changes to Jira issues. This gives flexibility, but it also means more custom logic to maintain.
  • Bi-directional updates need guardrails: You’ll need a reliable way to prevent update loops when changes come back from Jira, typically via correlation IDs or custom flags.
  • Rich data handling is non-trivial: Attachments, comments, and inline text don’t sync automatically. Each requires additional API calls and error handling.
  • Traceability and scale: As volume grows, retry logic, auditing, and failure handling become just as important as the initial integration logic.
In your case, you may want to explore OpsHub Integration Manager (OIM), a ServiceNow Partner. It’s a no-code, plugin-free platform built for bi-directional ServiceNow–Jira integrations, preserves rich data like attachments and comments, and works out of the box without custom scripts.
Hope it helps!
