09-16-2026 04:59 PM - edited 09-16-2026 05:01 PM
I have a requirement to nudge users who's incidents are on hold and not updated in 5 day. So I was thinking I could use a flow to put in work notes ask the assigned to, to provide updates on there incidents. But I don't want them to fall off because my flow added work notes. I know I can use autoSysFields(false) in a GlideRecord script but I was wondering if this can be done in flow without having to make my own action?
Flow Designer
Workflow Automation
09-16-2026 10:11 PM
Hello @brianlan25 ,
As per my understanding, it is not possible to update Work Notes using Flow Designer without affecting the system fields, since the standard Update Record action does not provide an option equivalent to autoSysFields(false).
If you are okay with using autoSysFields(false), you can use it in a Script step. Otherwise, if the requirement is simply to notify the Assigned To about an Incident that has been on hold for 5 days, you can send a notification to the Assigned To instead of updating the Work Notes.
If this helps you then m ark it as helpful and accept as solution.
Aditya
09-17-2026 08:55 AM
Hi @brianlan25
Unfortunately, you cannot suppress sys fields (like sys_update_on) natively in Flow Designer without a custom action.
Option1 : You can write your own custom script inside a standard Flow Script step
Sample code:
if (gr.get(inputs.sys_id)) {
gr.autoSysFields(false); // don't update sys_updated_on / sys_updated_by
gr.setWorkflow(false); // skip BR(optional but common)
gr.setValue('work_notes', inputs.work_notes);
gr.update();
})(inputs, outputs);
Option2: using Scheduled Script (skip Flow entirely)
If the nudge logic is straightforward, a Scheduled Job with a script might be simpler end-to-end:
Sample code
gr.addQuery('state', 'on_hold');
gr.addQuery('sys_updated_on', '<', gs.daysAgoStart(5));
gr.addQuery('assigned_to', '!=', '');
while (gr.next()) {
gr.work_notes = 'This incident has been on hold for 5+ days without an update. Please provide a status update.';
gr.update();
09-22-2026 07:39 AM
I have decided to use a scheduled job along with a mail script that will send 1 notification with a list of task that need to be updated. Instead of one notification per task.
