When is the deprecation date for Legacy Workflow Engine?
TamojitD
Hi Team,
As we know the legacy workflow editor has entered the maintenance state from last couple of years. Can anyone confirm the deprecation of workflow editor in Australia version?
if Yes, in that case is it required to migrate the legacy workflows to workflow studio flows/subflows before the upgrade process?
If No, can we perform the Australia upgrade with legacy workflows in mid 2026? and is there a confirmed deprecation plan for legacy editor?
Please help.
Tamojit
Bimschleger
Hi @TamojitD , I lead the product team for Flow and Workflow. At this time, there are no plans to deprecate the Legacy Workflow engine.
As of the Zurich release, ServiceNow no longer ships legacy workflows out of the box for new instances. However, any existing legacy workflows that you have on an existing instance will continue to run perfectly fine.
As others have noted above, we recommend building all new automation in Flow Designer.
11 REPLIES 11
kevinanderson
Giga Guru
Our org is in the middle of a large legacy workflow to flow migration.  I have some thoughts on the topic here: What do you do with more than 500 legacy ServiceNo... - ServiceNow Community
cuesawdue
Very good
