Workflow to flow design
08-12-2026 12:08 PM
I need to convert this workflow logic script in flow design. So, how we can implement this?
08-12-2026 01:57 PM
Hi...are you saying the solution you created works in your dev environment but not Test? I have seen flow act oddly and sometimes you may need to go in and make a small change like add a note or such, save it and then activate it again to make sure it compiles correctly.
08-12-2026 02:05 PM
the thing is I used with look up records action. In one instance it is working fine. In another, I am unable to select the data pill. It is grayed out and that fields are visible in that selected table. And I tried using custom action also, It is not working fine. Approval is not pushing it is show like no valid approval, that the users are active.
08-13-2026 05:10 AM
When you look at the run of the flow instance, do you see the values in the logs?
08-20-2026 10:02 AM
Hi @Kanimitha S ,
Pls check the run_as and the scope of the flow, could be an issue of application scope or run_as user access.
Regards.
