Indoor Mapping: Furniture Inside Room Not Showing
SVVSatyaM
Hi Community,
We are currently implementing WSD and have encountered an issue after uploading a CAD file in Map Studio. The CAD file includes some furniture within a closed room. We can see the furniture on the floor plan during the import process, it becomes invisible after importing the room as a polygon.
The furniture and the room are on different layers. I have attached screenshots for reference.
Can someone please let us know if it is possible to display the furniture inside the room?
Thank you!
@SVVSatyaM You can also make this adjustment in Map Studio with View Editor. Make sure to align the Place Type configuration with any updates you make through View Editor. Otherwise, the configuration will get overwritten when you do an Indoor Map/WSD Sync.
Hi @SVVSatyaM,
This is going to be the same as before - you'll want to adjust the Opacity for the Place Type of the Room.
I assume the Opacity is set to 1 - try updating it to .25 or lower
Best,
Connor Lyons
Consultant at Infocenter
CSA | CAD | 15x CIS
LinkedIn
Please mark answer correct and/or helpful for others reading this with the same issue/question.
