Manual Approval - Without Updating Flow Designer
09-21-2025 10:35 PM - edited 09-21-2025 10:36 PM
Hi Community Members,
Kindly, help me solve below scenario:
Scenario: We have an RITM/ Change where approvals have already been triggered for certain people. Now, we want to add additional approvers or update existing approvers.
Solution:
1. I tried to add Manual Approver (Users) in approval action activity in flow designer. This enabled that whenever an existing RITM or CHG will get new approval inserted then that approval record will also get tagged to flow context and hence approval of the newly inserted approver is also required. But this solution will require a lot of manual work if I want this manual approver functionality for more than 150 Flows .Hence, I want a generic solution.
2. So as a second solution, I tried to create a UI action on task table (so the button will be visible on RITM/ CHG) i.e when button is clicked on RITM then it will update the existing approver attached to RITM and since existing approval is updated and hence flow context also doesn't break . But this solution only worked when I tried as an admin User and doesn't work for non admin user .
Kindly, suggest a feasible solution so that I can update or insert new approval to RITM or CHG and upon approved by new approver the flow should move forward (without breaking flow) .
Manal Aquil
Architect
09-22-2025 03:39 AM
what error it gave with the UI action?
It was unable to update the approval record?
share the error details and screenshots.
09-22-2025 03:40 AM
Another approach
-> create subflow which accepts task sysId and list of additional approvers
-> Insert new approval records (sysapproval_approver) linked to the task dynamically.
-> Updates the flow context to include these new approvals so the flow waits for them too.
09-22-2025 09:25 AM
Thanks for responding @Ankur Bawiskar
Even If create a subflow I will need to call this subflow in 150 existing flows .
I need generic solution so that I should not update any existing flow
09-22-2025 05:10 AM
Hi @Manal AQUIL
May you try runs server-side under system privileges (so it’s not blocked by ACLs).
Example server-side insert:
var gr = new GlideRecord('sysapproval_approver');
gr.initialize();
gr.approver = '<user_sys_id>'; // new approver
gr.sysapproval = current.sys_id; // RITM or Change
gr.state = 'requested';
gr.insert();
