Query on/Issue with 'Reference Attribute' for Business Serice and Service Offering
Suggy
CSDM says relationship between 'Business Serice' and 'BS Offering' is "REFERENCE ATTRIBUTE
Q1 - What was the reason to use 'Reference Attribute'? Why cant we use 'CI relationship' itself?
Q2 - Are we not supposed to create CI realtionships for BS and BSO? Any issues?
As per this post we need to use the Dependency Views --> Map Related Items
Q3 - In this case, if I go to Business Offering 'BSM map view', I still cannot see this relationship in the map, but can see in from the 'Business service' form. Isnt this a gap? Any solution for this?
@Barry Kant  @CMDB Whisperer or any other experts, if you could answer this please 🙂
Barry Kant
Good day Suggy,
Q1 - The very generic idea most likely is:
References are used when there is a single relation (parent).
Relations are used when there are multiple relations possible. There is a downside as references are not (good) visible in a dependency view.
Q2 - you can do this but not to replace the reference. The reference is used in the logic eg in DPM. What can be done is to add a CI relations based on the reference (to keep it in sync where the reference is in the lead).
Q3 - I am not sure on this one. can you give more details on this?
BR,
Barry
Thank you so much for your inputs and time @Barry Kant  !!!
Barry Kant
Hi Suggy,
1 thing to add.
Initially ITSM has Impacted Services/CIs for the output of Impact Analysis.
Since some releases 2 related lists are added for:
  1. (Impacted) Service Offerings
  2. (Impacted) Business Applications
This functionality is driven by system properties:
Property Value OOTB value Comments
com.snc.incident.populate_ business_application TRUE FALSE When TRUE the impact analysis will write affectedBusiness Applications in the related list
com.snc.incident.populate_ service_offering TRUE FALSE When TRUE the impact analysis will write affectedService Offerings in the related list
com.snc.change_request.populate_ business_application TRUE FALSE When TRUE the impact analysis will write affectedBusiness Applications in the related list
com.snc.change_request.populate_ service_offering TRUE FALSE
When TRUE the impact analysis will write affected Service Offerings in the related list
com.snc.incident.refresh_ impacted.include_affected_cis TRUE FALSE
When TRUE The input for impact analysis is the related list with affected CIs.
Also:
impact analysis will be done from svc_ci_assoc table (not in cmdb_rel_ci table).
When FALSE the input for impact analysis is the Configuration Item attribute and the impact analysis will be done from cmdb_rel_ci table.
com.snc.change_request. refresh_impacted.include_affected_cis TRUE TRUE
Also:
As subscriptions and Outages are made against Service Offerings this for me is good enough to have as output. Communication can be done accordingly and KPIs in Enterprise Portfolios are calculated against Service Offerings as well.
If parent Services are needed then just capture the parent in the Service Offerings.
Note:
When impact analysis is done from svc_ci_assoc table your Application Services needs to be one of those classes:
  • Mapped Application Service
  • Dynamic Application Service
  • Tag Based Application Service
Dynamic CI Groups by the nature of it works similar.
BR,
Barry
Suggy
Thanks Barry.. This is very important to "impact analysis will be done from svc_ci_assoc table (not in cmdb_rel_ci table)."
