I can't find "sn_flow_designer.max_action_vars" and "sn_flow_designer.max_script_variables" .
Rika Tateyama
Hi there!!
I am currently looking to set up more than 20 inputs in a custom action in the flow designer.
However, I have read on the net that to set more than 20 inputs, I have to change the value of
 "sn_flow_designer.max_action_vars" and "sn_flow_designer.max_script_variables".
(Location: System Properties [sys_properties] table)
I have searched for "sn_flow_designer.max_action_vars" and "sn_flow_designer.max_script_variables"
in PDI , but I can't find them.
Which "sn_flow_designer.max_action_vars" and "sn_flow_designer.max_script_variables" can be changed here?
These are just system properties, you can just create them.
Name = sn_flow_designer.max_action_vars
Value = the value you are after
Kind regards,
Mark
2020-2022 ServiceNow Community MVP
2020-2022 ServiceNow Developer MVP
LinkedIn
Community article, blog, video list
Any luck?
Kind regards,
Mark
LinkedIn
Mark Roethof
Hi there,
Any follow-up needed? Or was my answer sufficient?
Let me know.
If your question is solved, please close the topic by marking my answer as correct. This will help others searching for a similar question and will remove the topic from the unsolved list.
Kind regards,
Mark
LinkedIn
