approver and requested for same
sarfraz3
Mega Expert
I have a requirement in where if "approver" and requested for are same then the approver should not be able to approve the request (like he should be debarred from approval_admin role for that request) ....Please give some solutions...
14 REPLIES 14
thanks tom....it is showing now..
Nice, good luck!
zica
Giga Guru
Sarfraz,
if you are approving items from a workflow, then
I have a slightly different approach. Use the script section (check Advanced) on the Group Approval activity and remove the requested_by person from the group.
You will need to do a lookup of all group members from sys_user_grmember using a GlideRecord query and skip over the the requested_by approver. Something like this (untested):
answer = getUsers();
function getUsers() {
        var uList = [];
        var gr = new GlideRecord('sys_user_grmember');
        gr.addQuery('group', current.getValue('assignment_group'));
        gr.addQuery('user', '!=', current.requested_by); // may be current.variables.requested_by in your situation
        while (gr.next()) {
                          uList.push(gr.getValue('user'));
        return uList;
cminarich
Kilo Expert
I just had a similar situation.   I wrote a BR to prevent the creation of the approval record if the approver was the same as the requestor.   Hope this helps.
