Auto populate reference field based on other reference field
rickw1
Giga Contributor
Hi there,
I'm figuring out the best way to do this..
In my form, I have 2 fields: caller and hospital.
Caller refers to the users table, Hospital refers to the company table.
My goal is: whenever I populate the caller field, the system needs to lookup the hospital of that caller and needs to auto-populate that.
Example: Customer X is part of Hospital X. Customer X is the caller so will be populated in the caller field. The system recognizes that Customer X is part of Hospital X so hospital will be Hospital X.
Hope you guys can help me out!
rickw1
Giga Contributor
We got it working!
Client script:
    var ga = new GlideAjax('GetCustomerData');
  ga.addParam('sysparm_name','getFieldValue');
  ga.addParam('sysparm_field','u_reference_1');
  ga.addParam('sysparm_user_id', g_form.getValue('caller'));
      ga.getXML(DoSomething);
      function DoSomething(response) {
            var company = response.responseXML.documentElement.getAttribute("answer");
            g_form.setValue('company',company);
Script include:
var GetCustomerData = Class.create();
GetCustomerData.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
    getFieldValue: function() {
              var user = new GlideRecord('x_medt2_ihs_customers');
              user.get(this.getParameter('sysparm_user_id'));
              if(! user.sys_id){
                                return false;
        return user[this.getParameter('sysparm_field')];
Thanks everybody for the great help on this!
58 REPLIES 58
Ok Rick we are close to the solution .
Now, the only thing that you need is the name of the column of the field Caller on the form with number IHSRXXXX. I though It was the [incident] table, but maybe is a custom table.
So if you put on g_form.getReference('[NAME OF THE COLUMN]', getHospital); the above code should work.
Nope, the record is part of table x_medt2_ihs_it_support_request,
the caller record is part of table x_medt2_ihs_customers (extended from User table) and
the hospital record is part of table x_medt2_ihs_hospitals.
The name of the column of Caller? That would be caller ..
Umm. Interesting. Looking at the last code you post, it seems like getRererence is returning a [sys_user] record instead of [x_medt2_ihs_customers] table. That would explain the output "Undefined".
Could you check the dictionary of field Caller? Where is it pointing to? Maybe is pointing to User[sys_user] table, so it would shows all records on the "Parent" table. Think about if you what to show the records on [sys_user] table or if you want to show records on [x_medt2_ihs_customers] table. If you want to show only records on [x_medt2_ihs_customers] table, then you should change the dictionary record making Caller field point directly to [x_medt2_ihs_customers] table instead of [sys_user].
Check it and give us a feedback!
That absolutely right.
The thing is: I need to be able to log requests for employees and customers. Employees are in sys_user, customers are in x_medt2_ihs_customers. Caller is a reference to sys_user, but also shows records of the x_medt2_ihs_customers table. I would assume that would also work for now.
If there a way of providing a reference to sys_user and x_medt2_ihs_customers ?
Ok! Look, you can do this as a temporary workaround at the moment:
  var gr = new GlideRecord('x_medt2_ihs_customers');
  if(gr.get(newValue))
          g_form.setValue('company',gr.u_reference_1);
  else
        alert('User is not a customer and does not have Hospital assigned');
The best solution for a good performance is, as Paul Morris and Pradeep Sharma said, create and Ajax script and call it from the client script. Check this link out http://wiki.servicenow.com/index.php?title=Client_Script_Best_Practices#Example:_Asynchronous_GlideA...
Did it work?
