Create change from problem, but do not insert
Annirnita Dash1
Please help me out in creating a change request from problem but not inserting it. Since the Ui action which creates a change record is saved through it that runs, the mandatory fields not filled in and  continue to show as required. It should navigate to sys_is -1.
Below is the code and I have commented out line where it inserts.
var change = new GlideRecord("change_request");
change.short_description = current.short_description;
change.description = current.description;
change.cmdb_ci = current.cmdb_ci;
change.priority = current.priority;
change.company = current.company;
change.sys_domain = current.sys_domain;
change.type = 'Normal';
//var sysID = change.insert();
current.rfc = sysID;
var mySysID = current.update();
gs.addInfoMessage("Change " + change.number + " created");
action.setRedirectURL(change);
action.setReturnURL(current);
@Annirnita Dash1
you are not inserting so you won't get the CHG number
so these lines makes no point
change.parent = current.sys_id;
15 REPLIES 15
@Annirnita Dash1
Hope you are doing good.
Hi Ankur,
sorry for replying late,
I tried adding line number 8 and used in url... but it is not working.
Can you point out the problem here?
//action.setRedirectURL("/change_request.do?sys_id=-1&sysparm_query=short_description=" + current.short_description + "^description" +  current.description + '^parent=' + current.sys_id);
var url = 'change_request.do?sys_id=-1&sysparm_query=' + 'short_description=' + short_description + '^description=' + description + '^cmdb_ci=' + cmdb_ci + '^priority=' + priority + '^sys_domain=' + sys_domain + '^company=' + company + '^type=' + type + '^parent=' + parent;
action.setRedirectURL(url);
@Annirnita Dash1
Sorry I got the fix, below line  I did, as of now with limited fields:
var url = 'change_request.do?sys_id=-1&sysparm_query=' + 'short_description=' + current.short_description + '^type=' + current.type + '^parent=' + current.sys_id;
