Create custom time-based triggers for Flow Designer - every 2nd Tuesday of the Month
Peter Williams
Hello all
Happy New Years.
i have a requirement to create a custom time base trigger for Flow designer
what i need to do is:
1) have the trigger run every 2nd Tuesday of the month
2) have another trigger to run every 2nd Tuesday of a specific month ( ex. 2nd Tuesday of Jan. or 2nd Tuesday of Oct.)
i know that i can set the trigger to run daily but how do i calculate to for the other items above
any and all help is appricated
How would i incorporate this into the Flow Designer to check?
i am looking at the Scheduled Jobs in System Definations
i think it could work but i am not able to get the condition to work correctly
here is what i have
here is the condition script
// Condition Script
(function checkCondition() {
    // Get the current date
    var currentDate = new GlideDateTime();
    // Check if it's Tuesday
    if (currentDate.getDayOfWeek() == 3) { // Tuesday is represented as 3 in ServiceNow
        // Check if it's between the 8th and 14th day of the month
        if (isSecondTuesday(currentDate)) {
            // Condition is met
            return true;
    // Condition is not met
    return false;
// Function to check if the date is the second Tuesday of the month
function isSecondTuesday(date) {
    var dayOfMonth = date.getDayOfMonth();
    // Check if it falls between the 8th and 14th day of the month
    return dayOfMonth >= 8 && dayOfMonth <= 14;
cant see to get it to work correctly
Riya Kapoor
We have taken this feedback under consideration and launched Recurrence trigger that can solve this use case. You can read more about it here: https://www.servicenow.com/docs/r/build-workflows/workflow-studio/create-scheduled-trigger.html
Riya Kapoor
Sr. Product manager
ServiceNow
