Filter out users in a specific group from reference variable
CharlesG2504556
I have a User Reference variable on a catalog item. The BU does not want their names to be in the list of users. I created a script include:
filterOutByGroupName: function(group_name) {
      /* Will remove users of the specified group from the list */
      var found_users = [];
      var gr = new GlideRecord("sys_user_grmember");
      gr.addQuery("group.name", group_name);
      gr.addNotNullQuery("user");
      while (gr.next()) {
         found_users.push(gr.user.sys_id.toString());
      var ref_qual = "sys_idNOT IN" + found_users.join(",");
      return ref_qual;
And I have added this to the Advanced Ref Qual:
javascript: new UserFilterUtils.filterOutByGroupName('Reporting');
But, I am still getting the users from that group in the list. What am I doing wrong?
Thank you, Charles
Hi @CharlesG2504556,
Didn't go through the entire code but looks like it's missing a set of parenthesis
i.e.
new UserFilterUtils().filterOutByGroupName('Reporting');
Cheers
i.e.
Cheers
It's always those little things I don't notice, no matter how long I stare at it.
Thank you very much
I just copied/paste your reference qual. I noticed there's a semicolon at the beginning and It seems you are missing the () after the first function call. So it should be:
Updated reference qualifier:
javascript: new UserFilterUtils().filterOutByGroupName(groupName);
If my answer helped you in any way, please then mark it as helpful/Accepted.
