Group Approval for Flow Designer
Talvin Singh
Hello Reader,
I have a requirement to set Group Approval on the RITM for a Catalog Item.
So, there is a Single Line Text type variable - 'Approvers'. This field has the name of the Group that should be set as the Approval on the RITM.
For the Catalog Item, we are using a Flow Designer. In the 'Ask for Approval' action I do not any option to select dynamic values (Group name from the variable 'Approvers'). Below is the screenshot -
Sourav16
Instead of making a single line text field make that variable a reference type to (sys_user_group) table i.e. the Group table, then you would be able to use it as a data pill picker for approval in flow designer
Also make sure to set the state of your Group Approval as Requested as shown below to achieve your requirement:
Shloke
PeriyasamyP
Use inline script to set dynamic groups in approval. Please refer attached screen shots.
