Help with Record Producer Script - Having issues pulling Sys ID
Wendy Peterson
Someone helped me with this for a Table I have which in the Record Producer I have tons of variables but they only want to see the ones are that complete. I can get it to pull the values if i tell it the sys id to look for but I can't get it to pull the sys id of the record it just created. Any ideas? See the screenshot below the sys id is there and it's unique. TIA It's for a Record Producer that is put into a table with only like 4 fields and one of them is a comments section it wants the variable values to go into if they are completed. If they aren't completed they don't want to see them.
var gr = new GlideRecord('question_answer');
gr.addQuery('table_sys_id', current.sys.id); //sys_id of record in question
while (gr.next()) {
  if (gr.value && gr.question.type == 6) { //exclude questions with empty values
  current.u_comments +=(gr.question.getDisplayValue() + ":   " + gr.value.getDisplayValue() + "\n"); //display question and answer
current.u_aom_analyst = gs.getUserID();
Hi Wendy,
Can you please try the following and let me know how you get along: -
var sysID = current.getUniqueValue(); //find sys_id of current record
gr.addQuery('table_sys_id', sysID); //sys_id of record in question
gr.addNotNullQuery('value'); //exclude any variables with null values
var myComments = '';
while (gr.next()) {
  if (gr.question.type == 6) { //restrict question type
        myComments +=(gr.question.getDisplayValue() + ":   " + gr.value.getDisplayValue() + "\n"); //build comments
//set fields on record producer
current.u_comments = myComments;
I could only test this in a background script with a fixed sys_id so you'll have to let me know if it works for you.
17 REPLIES 17
Brent Sutton
Hi Wendy,
Try replacing "gr.addQuery('table_sys_id', current.sys.id); //sys_id of record in question" with:
gr.addQuery('table_sys_id', current.getUniqueValue());
This should work for you. Hope this helps
Brent
Nitesh Asthana1
Hi Wendy,
I noticed you typed sys.id. Is it a typo? Replace it with sys_id or use current.getUniqueValue().
Nitesh Asthana
I tried both with no luck. When I try gr.addQuery('table_sys_id', current.sys_id); //sys_id of record in question and replace current.sys_id with a certain sys id then it pulls that record fine.
gr.addQuery('table_sys_id', current.getUniqueValue()); //sys_id of record in question
while (gr.next()) {
and
while (gr.next()) {
I put an alert in and it sees the SYS ID it just won't pull the info into that record
