Help with Record Producer Script - Having issues pulling Sys ID
Wendy Peterson
Someone helped me with this for a Table I have which in the Record Producer I have tons of variables but they only want to see the ones are that complete. I can get it to pull the values if i tell it the sys id to look for but I can't get it to pull the sys id of the record it just created. Any ideas? See the screenshot below the sys id is there and it's unique. TIA It's for a Record Producer that is put into a table with only like 4 fields and one of them is a comments section it wants the variable values to go into if they are completed. If they aren't completed they don't want to see them.
var gr = new GlideRecord('question_answer');
gr.addQuery('table_sys_id', current.sys.id); //sys_id of record in question
while (gr.next()) {
  if (gr.value && gr.question.type == 6) { //exclude questions with empty values
  current.u_comments +=(gr.question.getDisplayValue() + ":   " + gr.value.getDisplayValue() + "\n"); //display question and answer
current.u_aom_analyst = gs.getUserID();
Hi Wendy,
Can you please try the following and let me know how you get along: -
var sysID = current.getUniqueValue(); //find sys_id of current record
gr.addQuery('table_sys_id', sysID); //sys_id of record in question
gr.addNotNullQuery('value'); //exclude any variables with null values
var myComments = '';
while (gr.next()) {
  if (gr.question.type == 6) { //restrict question type
        myComments +=(gr.question.getDisplayValue() + ":   " + gr.value.getDisplayValue() + "\n"); //build comments
//set fields on record producer
current.u_comments = myComments;
I could only test this in a background script with a fixed sys_id so you'll have to let me know if it works for you.
17 REPLIES 17
Thanks so much for your help. I got this working with your script and making this into a BR.
while (gr.next()) {
  if (gr.question.type == 6) { //exclude questions with empty values
        myComments +=(gr.question.getDisplayValue() + ":   " + gr.value.getDisplayValue() + "\n"); //display question and answer
myComments.update();
      })(current, previous);
siva_dirisala
Hello Wendy, the variables are not inserted into the database by the time the record producer script is run. So, you can move your logic from record producer script to a business rule on the table.
Oh dang any ideas on how I would make that script into a BR? I am lost at scripting TIA
