How to identify whether connection is established or not (ServiceNow with third party tool)
Srinivasu2
Hi Community,
How to determine if a connection has been established between ServiceNow and a third-party tool?
Srinivasu
Anand Kumar P
Hi @Srinivasu2 ,
To verify a successful connection between ServiceNow and a third-party tool,
1. Check HTTP Status Codes: In REST API interactions, click on test connection ui action link a status code of 200 OK indicates a successful request, while 201 Created signifies that a resource was successfully created.
2. Review IntegrationHub Execution History: Within IntegrationHub, navigate to the execution history to observe the status codes of your integration actions; 200 and 201 codes confirm successful executions.
3. Test with Postman: Use Postman to send requests to the third-party API by specifying the method, endpoint, and payload; receiving a 200 or 201 status code indicates a successful connection.
https://www.servicenow.com/docs/bundle/xanadu-api-reference/page/integrate/inbound-rest/reference/r_...
If my response helped, please mark it as the accepted solution ✅ and give a thumbs up👍.
Anand
