LOCKED OUT OF DEV INSTANCE- NEED URGENT HELP HAVE IMPORTANT WORK THERE
truskcr
I am LOCKED OUT of my dev incstance dev400129.service-now.com - i have very important work there- was configuring SAML sso and now my admin logon doesnt work.; HELP NOW!!!!!
15 REPLIES 15
Just PM'd you about the issue.
Hi @truskcr
Option 1:
  • Open an Incognito/Private browser window to clear any cached SAML or authentication state.
  • Go to your PDI URL followed by /login.do (e.g., https://dev400129.service-now.com/login.do)
  • Enter admin as the username and your current local admin password
Option 2:
If your local admin password is not working or you are locked out, you need to generate a new password through your Developer Site profile:
  • Log in to the ServiceNow Developer Site.
  • Hover over the Manage tab in the top right and click Instance.
  • Click the Action menu or Gear icon to reveal the Instance Management options.
  • Select Reset Instance Password
  • Wait for the Developer Site to provision a new, temporary password.
  • Use this new password alongside your admin username on the /login.do page
Already tried that- it did not work. Can you help me with getting in contact with a ServiceNow employee?
truskcr
Hi @truskcr
Did you try Developer portal option.
If you do not have any important things to take back up , you can try Manage My instance ->Action-> Reset and Wipe instance to reset your instance.
Yes, I did. I have got some important data.
truskcr
