Need help in JSON parsing
abjaffrey
Giga Guru
Hey Folks,
I'm just learning and practising development, I'm unable to complete the Script include & client script, need your help.
Can someone help with what went wrong
Script Include :
var getIncDetails = Class.create();
getIncDetails.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getINC:function(){
        var incArray = [];
        gr.addQuery('caller_id',this.getParameter(sysparm_user_id));
        while(gr.next()){
            var incDetails = {};
            incDetails.number=gr.number.toString();
            incDetails.priority=gr.priority.getDisplayValue();
            incDetails.short_desc=gr.short_description.toString();
            incArray.push(incDetails);
    return JSON.stringify(incArray);
    type: 'getIncDetails'
Client Script:
   var finalArray = [];
   var ga = new GlideAjax('getIncDetails');
   ga.addParam = ('sysparm_name','getINC');
   ga.addParam = ('sysparm_user_id',newValue);
   ga.getXMLAnswer(IncDetail);
   function IncDetail(response){
    var obj = JSON.parse(response);
    for(var i =0;i<obj.length;i++){
        finalArray.push('Incident Number : '+ obj[i].number +'\n'+'Priority : ' + obj[i].priority +'\n'+ 'Short Description : ' + obj[i].short_desc +'\n\n');
    // g_form.setValue('description',finalArray);
ga.addParam = ('sysparm_user_id',g_form.getValue('caller_id'));
Change these two lines as below in client script
ga.addParam('sysparm_name','getINC');
ga.addParam('sysparm_user_id',g_form.getValue('caller_id'));
12 REPLIES 12
Community Alums
Hi @abjaffrey ,
Can you try to print your response in info message and see what it is returning.
Try g_form.addInfoMessage("object is : " + obj + " and length is: " + obj.length);
Please confirm what is being printed in the message.
Hi @Community Alums
Thanks for the response, I've changed the client script as suggested but still no changes, after changing caller id the info msg dint show.
Gustav Aldenbra
Hi @abjaffrey
Can you try this client script. I have change getXMLAnswer to getXML.
   ga.getXML(IncDetail);
    var obj = JSON.parse(answer);
In the script include Can you log the array before the return statment using gs.info('incArray: ' + incArray) to see if the script include returns any data or even runs at all.
I've changed the codes as below but still no solution.
SI:
    getINC:function(){
        var incArray = [];
        var userID = this.getParameter('sysparm_user_id');
        gr.addQuery('caller_id',userID);
        while(gr.next()){
    gs.info('incArray: ' + incArray);
CS:
// function onChange(control, oldValue, newValue, isLoading, isTemplate) {
//    if (isLoading || newValue === '') {
//       return;
//    var finalArray = [];
//    var ga = new GlideAjax('getIncDetails');
//    ga.addParam = ('sysparm_name','getINC');
//    ga.addParam = ('sysparm_user_id',g_form.getValue('caller_id'));
//    ga.getXMLAnswer(IncDetail);
//    function IncDetail(response){
//  var obj = JSON.parse(response);
//  g_form.addInfoMessage("object is : " + obj + " and length is: " + obj.length);
//  for(var i =0;i<obj.length;i++){
//      finalArray.push('Incident Number : '+ obj[i].number +'\n'+'Priority : ' + obj[i].priority +'\n'+ 'Short Description : ' + obj[i].short_desc +'\n\n');
//  // g_form.setValue('description',finalArray);
//    //Type appropriate comment here, and begin script below
