Need help to pass parameters to eventqueue from Portal
DB1
I am trying to insert relationship in 3 different tables as shown below from a Custom Portal widget:///
	if(graddextuser2.active == true)
					var grextuserid = graddextuser2.sys_id.toString();
					var table_1 = [
						{'tblname':'cmdb_rel_person', 'col1':'user', 'col2':'ci','dev_key':'newauthcaller','prod_key':'newauthcaller1'},
						{'tblname':'u_m2m_sys_user_cmdb_ci_service', 'col1':'sys_user', 'col2':'u_cmdb_ci_service','dev_key':'newauthappr','prod_key':'newauthappr1'},
						{'tblname':'u_m2m_from_cmdb_ci_service_watchlist', 'col1':'u_user','col2':'u_cmdb_ci_service','dev_key':'newwatchlist','prod_key':'newwatchlist1'}
					table_1.forEach(function(element) {
						var k =0;
						var test = usedfor.split(",");
						test.forEach(function(value){
							var grCheckExistence3 = new GlideRecord(element.tblname);
							grCheckExistence3.addQuery(element.col1,grextuserid);
							grCheckExistence3.addQuery(element.col2, res[k]); //res[k] contains the CI sys_id
							grCheckExistence3.query();
							if (!grCheckExistence3.next()) {
								if(input.exUser[element.dev_key] == true && value == "Development")
									var graddRole = new GlideRecord(element.tblname);
									graddRole.initialize();
									graddRole[element.col1] = grextuserid;
									graddRole[element.col2] = res[k];
									graddRole.insert();
									flagmsg = 'true';
								if(input.exUser[element.prod_key] == true && value == "Production")
									//gs.addInfoMessage("User has been added successfully into Prod Key");
									var graddRole1 = new GlideRecord(element.tblname);
									graddRole1.initialize();
									graddRole1[element.col1] = grextuserid;
									graddRole1[element.col2] = res[k];
									graddRole1.insert();
									flagmsg = 'true';
							else
								flagmsg = 'newtrue';
							k++;
I need to pass table name and new user id just got created/inserted in to an event from Portal itself.
If possible, can someone help on how to achieve the same?
Like can I add gs.eventQueue(tablename, new user sysid)?
@James Chun @Dr Atul G- LNG @Abhishek_Thakur @Sandeep Rajput
Looks like something good, any issues with this?
See more of my content here.
