12-18-2023 07:23 AM
When i change a field (date) on a work task record, how can i make a work flow to also change a field in a work order record match that same change?
Thanks.
12-18-2023 08:58 AM
@cpinedatx94 You can create an onUpdate business rule on work order task which will set the date and time field on the parent work order.
12-18-2023 08:07 AM
Hi @cpinedatx94
Could you please provide more details please what field you are changing, you do via BR as well.
12-18-2023 08:11 AM
I have a date field in my Work order task record. When this date field is set or changed i need a workflow or script to automatically also change a date field to match it in the parent work order.
12-18-2023 08:15 AM
Hi @cpinedatx94
Have look here to get an idea
12-18-2023 08:36 AM
What i need to do has nothing to do with the state flow of the record. I simply need a field on my work order to match a field on my work order task when it is changed.
Example:
Time and date field is set to 12:00pm on work order task
then
Time and date field is automatically populated is automatically populated with the same value on work order.
