Need Work Flow help
cpinedatx94
When i change a field (date) on a work task record, how can i make a work flow to also change a field in a work order record match that same change?
Thanks.
@cpinedatx94 You can create an onUpdate business rule on work order task which will set the date and time field on the parent work order.
Hi @cpinedatx94
Do it via Flow Designer
Look Up each Record
WOTask Date =changes
Do for Each Record
Set the W O date.
or
The best one
https://www.servicenow.com/community/developer-forum/set-priority-of-incident-task-to-parent-inciden...
