Notification not trigerring via flow designer
kartikey
Hi Everyone,
I created a notification on the parent sn_hr_core_case table whose send when is set to 'triggered' , i have created a flow designer as well on the sn_hr_core_case table and in advance options set to run the flow on current and extended table.
But when i'm following the start conditions for any child table e.g. payroll case , it is not triggering the notification, but when i test the flow designer via 'test' button available on flow designer, i can see at that time the notification triggering (checked in the email logs i.e. sys_email.list)
does anyone know how i can make that happen? as i do not wish to create multiple flow designers and multiple notifications on each table.
@kartikey I am wondering why the classic trigger is not satisfied while the test button yes. check the values, or try deactivate and activate the flow again, sometimes it does the trick
