Onsubmit script is not working with script
is_12
Hello Community !
function onSubmit() {
    if (g_user.hasRole('sn_customerservice_agent')) {
        var ga = new GlideAjax('catalogUtils');
        ga.addParam('sysparm_name', 'hasExistingRITM');
        ga.addParam('sysparm_account', g_form.getValue('account'));
        ga.addParam('sysparm_userId', g_form.getValue('contact_name'));
        ga.addParam('sysparm_catalogItem', g_form.getUniqueValue());
        ga.getXMLAnswer(setData);
    function setData(response) {
        var answer = response;
        alert('reponse' + answer);
        if (answer == 'false') {
            alert(getMessage('You are not allowed to order as there is an existing request for this customer'));
           return false;
            alert("else if alert");
            return true;
I'm getting the alert message but form is getting submitted.
Tried with getXMLWait(), it is getting supported
2 ACCEPTED SOLUTIONS
@is_12
this worked for me in onLoad catalog client script
I hope I answered your question and you can enhance it further.
function onLoad() {
		var element = this.document.getElementsByClassName('btn btn-primary btn-block text-overflow-ellipsis ng-binding ng-scope');
		element[0].style.display = 'none';
Output:
23 REPLIES 23
@is_12
link shared by @palanikumar should help, you should enhance it as per your logic in catalog client script
Ensure you detect the correct HTML element
@is_12
function onLoad() {
Output:
palanikumar
You should update the logic in a way that form gets submitted only if the response is true. You can use this code
        return false; // Cancel the form submission
        g_form_submit(); // Submit the form only if the response is true
Thank you,
Palani
@palanikumar I need to disable the button order now button
