Onsubmit script is not working with script
is_12
Hello Community !
function onSubmit() {
    if (g_user.hasRole('sn_customerservice_agent')) {
        var ga = new GlideAjax('catalogUtils');
        ga.addParam('sysparm_name', 'hasExistingRITM');
        ga.addParam('sysparm_account', g_form.getValue('account'));
        ga.addParam('sysparm_userId', g_form.getValue('contact_name'));
        ga.addParam('sysparm_catalogItem', g_form.getUniqueValue());
        ga.getXMLAnswer(setData);
    function setData(response) {
        var answer = response;
        alert('reponse' + answer);
        if (answer == 'false') {
            alert(getMessage('You are not allowed to order as there is an existing request for this customer'));
           return false;
            alert("else if alert");
            return true;
I'm getting the alert message but form is getting submitted.
Tried with getXMLWait(), it is getting supported
2 ACCEPTED SOLUTIONS
@is_12
this worked for me in onLoad catalog client script
I hope I answered your question and you can enhance it further.
function onLoad() {
		var element = this.document.getElementsByClassName('btn btn-primary btn-block text-overflow-ellipsis ng-binding ng-scope');
		element[0].style.display = 'none';
Output:
23 REPLIES 23
sunil maddheshi
@is_12
You're using GlideAjax.getXMLAnswer(), which is asynchronous. This means the onSubmit() function completes before setData() finishes — so the form submission proceeds before the validation result is received.
If your goal is to validate the combination of account, contact_name, and catalog item whenever a specific field changes (e.g. contact_name or account), you can do this via onChange.
Here’s how to convert your script to an onChange client script (example: triggered when contact_name)
        ga.addParam('sysparm_userId', newValue);  // since contact_name is triggering
        ga.getXMLAnswer(function(response) {
            if (response === 'false') {
                g_form.showFieldMsg('contact_name', getMessage('You are not allowed to order as there is an existing request for this customer'), 'error');
Please mark correct/helpful if this helps you!
Muhammad Salar
Tera Sage
Try this, button will not disable but request can not be submitted for false
if (g_scratchpad.isFormValid) {
return true;
var actionName = g_form.getActionName();
alert('response: ' + answer);
g_scratchpad.isFormValid = false;
g_scratchpad.isFormValid = true;
g_form.submit(actionName);
return false;
return true;
Hi @is_12
You cannot use asynchronous GlideAjax inside onSubmit() if you want to prevent submission.
Use getXMLWait() (Synchronous Call)
Since you said getXMLWait() is working, that’s the expected behavior, as it waits for the server response.
Note: ServiceNow discourages getXMLWait() in client scripts because it's synchronous and can cause the UI to freeze temporarily.
You can try this script:
        var answer = ga.getXMLWait();
        var response = answer.responseXML.documentElement.getAttribute("answer");
        if (response == 'false') {
            return false;
    return true;
Thanks and Regards,
Chiranjeevi R
Please mark as Correct Answer/Helpful, if applicable.
is_12
@palanikumar @Ankur Bawiskar @Community Alums @Muhammad Salar @sunil maddheshi
Tons for Thanks for all your replay, It is working now
