RITM Variable Section has a reference field which does not get updated based on "Dependent field"
07-06-2025 09:35 PM
I have 2 fields under an RITM in the 'Variables' section called 'Service' and 'Classification'. 'Classification' is dependent on the value of 'Service'. This is working when creating a new work request in the Employee Center. However, when editing the RITM directly, the 'Classification' field is not being updated with values depending on the selected value from the 'Service' field. I have attached some images to provide clarification.
Is there a way to have the available option show up or are there any options like changing field type instead? For clarity, these are closed RITMs and these fields are only made editable using the Catalog UI Policy.
07-07-2025 12:31 AM
It would have been better to include images directly rather than adding as attachment
It becomes difficult opening 1 by 1 each of those and try to link them
Please share variable configuration for both the variables. It seems you added dictionary screenshots.
07-07-2025 01:19 AM
I see - I've included the following screenshots for the variables in question:
Category (reference type):
Subcategory (lookup select box):
07-07-2025 01:58 AM
1s variable Category should be also Lookup select box variable
did you give variable attributes in the 2nd variable as this
ref_qual_elements=service
Also I didn't understand your ref qualifier in 2nd variable, what does "Value is" mean?
07-07-2025 02:05 AM
this is my setup and it worked on catalog form and RITM form as well
I used Lookup Select box and pointed to sys_choice table for incident category and subcategory dependency
Incident Category variable
Incident Subcategory variable
Output: The dependency works in RITM form
The Dependency works on Catalog form as well
07-07-2025 06:47 AM
Hi @Ankur Bawiskar ,
Thanks, I think you have pointed me in the right direction. After configuring the category(Service) as a Lookup select box and having the following setup, it shows properly in the RITM (I added the 'element' after the pre-existing conditions' under Reference Qual)
However, on the sub-category (Classification), I tried to pattern it similar to yours but no values are showing up. Would you know which part am I misconfiguring this field?
