‎10-07-2024 08:05 AM
Dear community,
I would like to clarify few details about creation of release and planning the scope
1) If I understood correctly, from the Release planning I can create a new release record only if I have Version.
i.e.: for each product we would like to release version needs to be created.
2) creation of Features - is using Features or optional?
scenario: DPR will not be integrated with JIRA to import any features or Epics.
3) Can I add arefacts from Epic/User stories from the Agile Development 2.0 to the Release planning?
I see in the documentation managing data from external tools but did not find information how to add artefacts and check data within the SN.
4) As per the documentation there should be a system property: ' - Create a release with a wizard (servicenow.com)
The number of Included products that can be added to a release depends on the system property sn_dpr.multi_product.included_products_limit. A release admin can update the value of this property to increase or decrease the limit in the SN Docs site.' Manage product hierarchy using Included products' (servicenow.com)
I cannot see such property in our demo instance, could you please advise?
Could you please provide some examples/scenario for using the product hierarchy?
Thank you very much
‎10-22-2024 09:06 AM
Hi @Alpa82, this feature of adding included products when creating a release using the wizard is available starting Nov'24 store release which is DPR v1.3
‎10-22-2024 08:41 AM
Are you referring this:
‎10-22-2024 08:51 AM
I added products into the 'Included Products', that is available even without the system property.
However based on the below article I understand I should be able to add/remove the included products when creating a Release using the release wizard and I do not see this option there:
My understanding is that it should be possible to add to the release the included products here
‎10-22-2024 12:36 PM
Thank you very much @Sai Teja1 for the clarification.
Since the information about the included products is available already on Docs, without specifying that it will be available only from the November, it was not clear it is not yet available in the DPR.
Is there anywhere published an overview what else will be included in the upcoming releases (e.g. DPR v1.3)? it would be great to be aware.
In the Digital Product Release release notes are only the past releases
Thank you very much
‎12-02-2024 06:50 AM
Hello @Sai Teja1 , could you please also advise on the question
3) Can I add artifacts from Epic/User stories from the Agile Development 2.0 to the Release planning?
I see in the documentation managing data from external tools but did not find information on how to add artefacts and check data within the SN.
Thank you
