01-27-2025 11:35 AM - edited 01-28-2025 02:21 AM
I created a dev instance and cloned the employee taxonomy as instructed in this YouTube video.
https://youtu.be/3WlXSWiWPrk?si=Vw8XyNIqAZ1N5oSW
When I replace the employee taxonomy with the cloned taxonomy, it does not appear on the employee portal.
its an exact clone of ootb employee but renamed.
Any help?
01-29-2025 01:25 AM - edited 01-29-2025 01:28 AM
Got the issue,
You need to sync the data.
Go to Advanced Portal Navigation on navigation.
Open the active true record.
See the related list, the Taxonomy with Employee as the parent is still true in menu Items. You need add the new entry with cloned Taxonomy and see if it works.
Tried in my OOB and it works!
Got the issue,
01-29-2025 06:32 AM
Thanks for your help. It worked
01-28-2025 10:58 AM
I now tried it on a new dev instance with the same result.
Can someone else try it in a Xanadu release?
