Need help for reporting on documentation for asset disposals
Jerry Ong
I need to reporting on outstanding documenation tasks for existing Hardware Disposal orders. Can I know how to create such a report?
Thank you.
Jerry Ong
sandeepdutt
Hi @Jerry Ong ,
You can create a report on the hardware asset table and add a filter where "Hardware disposal order stage" is Documentation. As this is where the task for Documentation for the disposal record is attached.
Sandeep Dutta
Please mark the answer correct & Helpful, if i could help you.
Hi Sandeep,
Thanks for the heads up, will try it and let you know.
Ankur Bawiskar
@Jerry Ong
so what did you start with and where are you stuck?
Jerry Ong
Hi Folks, I tried and could not pull the asset records from the query:
Can someone advise me? 🙂
Thanks!
