Difference between gs.hasRole(‘abc ’)and gs.getUser().hasRole(‘abc’) if I want to use in acl script
Vasavi4
Difference between gs.hasRole(‘abc ’)and gs.getUser().hasRole(‘abc’) if I want to use in acl script. Which one is better. I saw same functionality when using both ways. Please suggest.
Thank you
Saurav11
hello,
As you yourself saw in the above case both can help you achieve your goal of hasrole
Also there is no documentation of which one is better than the other.
However when look at OOB ACL 90 percent of them using the hasrole syntax is using the below:-
gs.hasRole(‘abc ’)
So I believe you should also follow the same.
Please mark answer correct/helpful based on Impact
Vasavi4
Thank you
If my answer helped you, can you also mark it as correct.
Thanks.
