Lists on base HR Workspace not visible for non-admin users
Lukasz Bojara
Hello HR Experts,
We have an issue in our implementation. All non-admin users can not see lists in the HR Agent Workspace.
To clarify:
  1. Users have sn_hr_core.basic role
  2. Users have workspace_user role
  3. Users have canvas_user role
  4. Users have access to HR cases as they have no issues while working from the "standard" UI.
  5. Audience for those lists is set to sn_hr_core.case_writer role, which they have.
  6. Lists are there, admin can see it.
  7. It is not a custom workspace, it an OOTB one.
So to summarize, the issue is only connected to Agent Workspace for HR Case Management and only for non-admin users.
I have debuged the Securty Rules, I see that access those lists is denied but the 4 ACLs listed below are not evaluated at all, maybe becouse those are OOTB ones from global scope, but you can not just replicated them for Workspace scope, the * ones can only be created from global.
 Any Ideas?
12 REPLIES 12
Hi @Lukasz Bojara
We are experiencing the same issue with the same set up. Were you able to fix the issue?
Thank you so  much for your response, it worked for me!
CelesteGro
We are experiencing the same issue where non-admin users cannot see the lists under the "Lists" column, but all of the above items are all set up. We originally had a classic workspace and have since downloaded the HR configurable workspace plug. We haven't created any new lists or variants. All OOB. Any other ideas what it could be?
Hi @CelesteGro ,
Can you verify the OOB list are applicable to non-admin users?
sys_ux_applicability_m2m_list - Modify the script to make the field visible only to non-admin users with specific roles.
Pradeep
I can verify that all lists are applicable to non-admin users. There is an sn_hr_core.case_reader  and sn_hr_core.case_writer  role for each list. I also did a test of deactivating all of the list categories and lists under each category except for the "All HR cases " category and "All" list and the non-admin users can still not see the Lists.
