Reference field values are not visible in Portal
Ranjit Singh Ra
I have an HR Service (Scope - Human Resources: Core) in the ESC Portal.
I have created a custom table "Routing ID" in Global scope which extends CMDB CI Table.
I have a variable in the HR Service which is referenced to the custom table. I have records in the custom table but still I am unable to see any records from the Portal. It says "no matching records found"
I have given the custom table Read ACL to my user, and also given the cmdb_read role to my user, still the same issue.
Please let me know what I can check to get this fixed.
Thank you.
16 REPLIES 16
Yes, I have set the Display to True for one field:
Still no difference.
Is there any specific requirement for inheriting table from Configuration Item Table? Also have you done any configuration to CMDB CI table ?
No configurations are done on the table. It's just that we need a table to store the IDs. We have a limitation of creating a table in HR Scope therefore created the custom table in Global and extending the Configuration Item table.
Interestingly,
I updated the table of the referenced variable to "Incident" and I am able to see incidents in that variable from the Portal.
It means, the issue is just with the custom table.
Yes, Because configuration item table is having restrictions and hence same restrictions are being applied to your trigger table, I would like to suggest create a Stand alone table instead of extending as there is security issues and as per your requirements you just want to store ID's , no dependency for CMDB CI table.
Let me know if this works ...
