Task to be generated 7 days prior to termination date using flow designer
07-26-2022 03:08 AM
We have a requirement to generate tasks under a parent HR Case where the tasks must be generated 7 days prior to effective date of termination? How to acheive the same through flow designer?
09-22-2023 04:23 AM - edited 09-22-2023 04:24 AM
Hi @Ankur Bawiskar ,
I am working on a flow design and creating a catalog task in the flow design itself.
There is a date time field (for example 'X') on the RITM.
Requirement is that task what I am creating on the flow design itself should be triggered before 45 days of that date time field's (X) value.
If that date time field value is 1st of December, then that task will be created on 16th October.
I am not able to achieve it through flow design. Could you please help me out as it is so urgent.
Thanks&Regards,
Abhisek Chattaraj.
09-22-2023 04:38 AM
Can you post a separate question for this as this is an older thread?
✨ Certified Technical Architect || ✨ 9x ServiceNow MVP || ✨ ServiceNow Community Leader
09-22-2023 04:44 AM - edited 09-22-2023 04:50 AM
New question is posted. Could you please help me out as it is so urgent.
Thanks in advance.
Abhisek Chattaraj.
