Configuration of Incident Resolution SLA for Upgrade/Downgrade then SLA should change
Pramod Pandey2
HI Communty,
Whenever the priority of the incident is upgraded from low priority to high priority,
Then the SLA should start from the time the priority was updated.
AND
Whenever the incident is downgraded from high priority to low priority,
Then the SLA should start from the time the incident was created (no change)
Pramod Pandey
9 REPLIES 9
Hi Mark,
Thanks for explanation, it would be really helpful if you can share 1 or 2 real scenario why we should not implement this requirement.
So i can explain to client.
Pramod Pandey
Satishkumar B
Hi @Pramod Pandey2
to configure Incident Resolution SLAs to adjust based on priority changes:
  1. Define SLAs for Each Priority
    • Create SLA definitions for each priority level (e.g., Critical, High, Medium, Low).
  2. Configure SLA Conditions
    • Set Start Conditions for SLAs to trigger at incident creation.
    • Add Reset Conditions for higher priorities to restart the SLA when the priority is upgraded.
  3. Create Business Rule for Priority Changes
    • Create a business rule to detect priority upgrades:
      • Trigger Before Update when the priority is upgraded.
      • Use a script to cancel the current SLA and start a new one for upgrades.
HAPPY LEARNING
Please Mark it helpful 👍 and Accept Solution ✔️ !! If this helps you!!
Dr Atul - LNG
csa #ServiceNow #TechnoFuncational Disclaimer: These videos are from my training batch. These videos did not promote any ServiceNow Sales pitch or marketing. These videos are only for knowledge purposes & basic on my experience & Knowledge. Redistribution or copying of functionality is not ...
Udit5
Hi @Pramod Pandey2 ,
Did you get a solution for this? I have the exact same requirement, how did you achieve this? would really appreciate your help.
Udit Gupta
Please read through all replies. This requirement doesn't make sense from an SLA perspective.
Next to that: raising your own question with your requirements may get you an answer faster than replying to a months old question.
