How to calculate OOTB Business Duration in Incident Metrics
Manikanta G
Hi Guys,
How to calculate the OOTB Business Duration field in Incident Metrics, I have checked in Incident Metrics only the Duration field is calculated, not Business Duration. I want to Calculate Business Duration as well and only in the scheduled SLA, Duration field is calculating 24/7 not in the SLA Scheduled timelines.
I am new to ServiceNow, working in support, and need someone's expertise on how to enable/calculate the Business duration field. Is any Property, Script required for this?
Mani
Harish Kota
Hi Manikanta,
This can achieve by using before business rule, please make sure you can create this in your non-prod instance and test, as you mentioned you are working in support, please check with your development team as well on this and proceed.
Business Rule:
When to Run: Before - Insert and update
Advanced Script:
// Add your code here
var gr = new GlideRecord("metric_instance");
gr.addEncodedQuery('end!=NULL^business_duration=NULL');
gr.autoSysFields(false); // so that the records don't have system updates
while (gr.next()) {
var gsBusiness = new GlideSchedule('sys_id'); //update sys_id of your schedule
// Get duration based on schedule
gr.business_duration = gsBusiness.duration(gr.start.getGlideObject(), gr.end.getGlideObject());
gr.setWorkflow(false);
gr.update();
})(current, previous);
Harish Kota
Please hit like or Accept the solution if it works for you.
Hi @Harish Kota, can you please help to clarify on which table do we need to write the business rule? Is it metric instance table or the incident/request/problem table on which the metric definition is created?
Chandan
