How to copy work notes and additional comments from Child incident to parent incident?
Jyoti Mehta
Hi Everyone,
we have a requirement where work notes and additional comments changes on child incident should be copied to parent incident also.
can you please help us to achieve this ?
Thanks in advance!
Deėpak Sharma
Hello @Jyoti Mehta
To copy work notes and additional comments from a child incident to a parent incident in ServiceNow, you typically need to create a Business Rule. Please follow below steps:
1. New Business Rule: Click on “New” to create a new business rule.
2. Define Basic Information:
- Name: Give the business rule a descriptive name, e.g., “Copy Notes from Child to Parent Incident”.
- Table: Set this to “Incident [incident]” as you’re working with incidents.
- Advanced: Check this box because you’ll be writing a script.
3. When to Run:
- When: Before Inserted/Updated
- Filter Conditions: “Parent Incident” field is not empty.
- Script: Enter your custom script here.
// Ensure there is a parent incident
    if (current.parent_incident.nil()) {
    var parentInc = new GlideRecord('incident');
    if (parentInc.get(current.parent_incident)) {
        // Concatenate current comments and work notes to the parent incident
        // Assuming ‘comments’ and ‘work_notes’ are the fields for additional comments and work notes, respectively
        if (!current.comments.nil()) {
            parentInc.comments = "Child Incident Update: " + current.comments + "\n\n" + parentInc.comments;
        if (!current.work_notes.nil()) {
            parentInc.work_notes = "Child Incident Update (Work Note): " + current.work_notes + "\n\n" + parentInc.work_notes;
        parentInc.update();
Note: Please Mark this Helpful and Accepted Solution. If this Helps you to understand. This will help us a lot.
Thanks & Regards
Deepak Sharma
Deėpak Sharma
Hi @Jyoti Mehta
check with this approach
Thanks & Regards
Deepak Sharma
