Variable set is hiding when submitting from Order guide
11-21-2025 01:02 AM
I have an order guide, in which 2 catalog item are there. one is pc purchase and other is new hire. When i submit from order guide then a variable set in pc purchase should be visible on ritm . When i submit pc purchase standalone then that variable set should not visible on ritm. It is working fine in platform view . But on service portal in ritm the variable set is not hiding.
For that i have applied client script on ritm
Does anyone has any idea?
11-21-2025 03:26 AM
Could you please confirm where this script i have to apply?
I have applied on catalog client script and check the 'applies on catalog item view' and 'applied on requested item' true. But still in RITM record on portal when submit from order guide, the variable set is not showing. It should show
11-21-2025 03:36 AM
yes applies on catalog item
did you add alert and see?
if it's not going inside IF then some other script is hiding it
share both of your client scripts screenshots
11-21-2025 03:52 AM
when i am submitting from order guide then also it alert is coming and hiding the variable set
11-21-2025 04:29 AM
Sorry but we don't have access to your instance so you need to debug from your side.
why line 5 is added? it's not in my script I shared above
12-09-2025 09:17 PM
Hope you are doing good.
