Identification Engine: Discovery status is FAILURE, Identification sections in pattern failed: section: Azure Subscription identification, error: Match step predicate is not matched.
RamSagar
When am trying to validate the azure service account am getting the error -
Identification Engine: Discovery status is FAILURE, Identification sections in pattern failed: section: Azure Subscription identification, error: Match step predicate is not matched.  "
    "message" : "2020-11-04 13:45:09: Exception occurred while executing operation Cloud REST Query. Custom operation Failed to run script due to the following error: JAVASCRIPT_CODE_FAILURE: com.snc.sw.exception.CommandFailureException: Failed to execute cloud request. Reason: SSLHandshakeException:sun.security.validator.ValidatorException: PKIX path building failed: java.security.cert.CertPathBuilderException: Unable to find certificate chain. (script_include:AzureApiCommand; line 111). Custom operation Failed to run script due to the following error: JAVASCRIPT_CODE_FAILURE: com.snc.sw.exception.CommandFailureException: Failed to execute cloud request. Reason: SSLHandshakeException:sun.security.validator.ValidatorException: PKIX path building failed: java.security.cert.CertPathBuilderException: Unable to find certificate chain. (script_include:AzureApiCommand; line 111)",
Please find the below log:
  "name" : "Discovery Log",
  "status" : "FAILURE",
  "children" : [ {
    "name" : "Pre Pattern Execution",
    "id" : "pre_pattern_execution_script",
    "status" : "SUCCESS",
    "level" : 2,
    "messages" : [ {
      "message" : "2020-11-04 13:45:08: Getting pre pattern execution data generated by script."
      "message" : "2020-11-04 13:45:08: setAttribute(build_relation_from_host_sys_id,false)",
      "severity" : "DEBUG"
      "message" : "2020-11-04 13:45:08: setAttribute(no_relation,true)",
      "message" : "2020-11-04 13:45:08: setAttribute(pattern_runtime_mode,horizontal)",
    "type" : "NONE"
    "name" : "Selecting Pattern for Execution",
    "id" : "set_pattern_name",
    "level" : 2,
    "messages" : [ {
      "message" : "2020-11-04 13:45:08: Pattern: Azure Service account"
      "message" : "2020-11-04 13:45:08: setAttribute(pattern,Azure Service account)",
    "type" : "NONE"
    "name" : "Azure Subscription identification",
    "status" : "TERMINATION",
    "children" : [ {
      "name" : "Create Service Account From Input Params",
      "level" : 3,
      "messages" : [ {
        "message" : "2020-11-04 13:45:08: Library 'Create Service Account From Input Params' executing",
      "type" : "STEP_TYPE"
      "name" : "Create service account table if doesn't exist",
      "status" : "NOP",
      "level" : 3,
      "messages" : [ {
        "message" : "2020-11-04 13:45:08: Step condition is false. step not executed.",
        "message" : "2020-11-04 13:45:08: Execution time: 0 ms",
      "name" : "Add credentials and account ID to service account table if don't exist",
      "status" : "NOP",
      "level" : 3,
      "messages" : [ {
      "name" : "Verify account ID",
      "level" : 3,
      "messages" : [ {
      "name" : "Get Azure Subscriptions",
      "status" : "MIXED",
      "level" : 3,
      "messages" : [ {
        "message" : "2020-11-04 13:45:08: setAttribute(headers,)",
        "message" : "2020-11-04 13:45:08: setAttribute(method,GET)",
        "message" : "2020-11-04 13:45:08: setAttribute(formatted,true)",
        "message" : "2020-11-04 13:45:08: setAttribute(body,)",
        "message" : "2020-11-04 13:45:08: setAttribute(url,https://management.azure.com/subscriptions?api-version=2016-06-01)",
        "message" : "2020-11-04 13:45:08: setAttribute(headers,null)",
        "message" : "2020-11-04 13:45:08: setAttribute(body,null)",
        "message" : "2020-11-04 13:45:09: Execution time: 407 ms",
      "name" : "Verify if we have any valid response",
      "level" : 3,
      "messages" : [ {
        "message" : "2020-11-04 13:45:09: Execution time: 0 ms",
    "level" : 2,
    "type" : "IDENTIFICATION_SECTION_TYPE"
    "name" : "discovery",
    "id" : "discovery",
    "children" : [ {
      "name" : "Check Processing Success",
      "id" : "Check Processing Success",
      "level" : 3,
      "messages" : [ {
        "message" : "2020-11-04 10:45:10: Identification Engine: Discovery status is FAILURE, Identification sections in pattern failed: section: Azure Subscription identification, error: Match step predicate is not matched.  "
      "type" : "NONE"
    "level" : 2,
    "type" : "NONE"
  "level" : 0,
  "messages" : [ {
    "message" : "2020-11-04 13:45:08: Task is running on MID server VWUNOWAPP101_AD",
    "message" : "2020-11-04 13:45:08: setAttribute(cmdb_ci_cloud_service_account,[{}])",
  "type" : "NONE"
Any thoughts why the error and unable to validate the service account.
Thanks in Advance
14 REPLIES 14
@SriniK yes i tried to debug the with the pattern, but it is failing at Azure subscription identification and getting the error.
Do i need to add any certificate to MID Server
am using the complete OOTB pattern no modification were done.
@Ashutosh Munot No am still using the OOTB patterns but any reason why am getting the below error.
does it belongs to any certificate to added to MID server?
Can you sit with your network guy and see where the connection is getting dropped? That can help you to understand what is happening.
Ashutosh
Venky VA
Are you sure service account is active? in payload service account is not set
