is there any way to push metrics manually to servicenow for anomaly detection?
Since my resources are limited, we don't have a mid server installed or any third-party integrations set up.
Still, we're interested in gaining hands-on experience with anomaly detection using Machine Learning. Do you have any suggestions or leads on how we can proceed?
Understood.  Because the anomaly detection runs as threads inside the MID JVM, there's no way to remove the MID from the equation, even for testing/learning purposes. So while it is feasible to use the direct metrics API to ingest the raw data, without the MID you would not see any anomaly alerts.
AJ_TechTrek
Hi @Community Alums ,
You can installed the MID on any AWS or Azure resource  as Mid Server is Mandatory for Metric collection.
Apart from that OOB MID Metric you can collect, which you can enable and received as ITOA_metric, Please refer the ServiceNow Documentation on Metric/Operational Intelligence on this.
AJ
