REST Step POST Flow Designer Error
Rachna S
Hello All,
We are getting the following error on making a Post REST call to certain endpoints-
Operation(Failed Delink Request Monitoring Subflow.ef25c0cbdb0ae0106e556e8cd396195b.a62540cbdb0ae0106e556e8cd396190c) failed with error: com.snc.process_flow.exception.OpException: Request not sent to uri= http://XXXX : java.net.ConnectException: Connection timed out (Connection timed out)
at com.snc.process_flow.operation.AbstractHttpOperation.processError(AbstractHttpOperation.java:201)
at com.snc.process_flow.operation.AbstractHttpOperation.requestAndProcessResponse(AbstractHttpOperation.java:129)
at com.snc.process_flow.operation.AbstractHttpOperation.invoke(AbstractHttpOperation.java:111)
at com.snc.process_flow.operation.RetryableIntegrationOperation.run(RetryableIntegrationOperation.java:46)
at com.snc.process_flow.engine.Operation.execute(Operation.java:165)
at com.snc.process_flow.engine.ProcessEngine.executeOps(ProcessEngine.java:497)
at com.snc.process_flow.engine.ProcessEngine.run(ProcessEngine.java:413)
at com.snc.process_flow.engine.ProcessAutomation.run(ProcessAutomation.java:66)
at com.snc.process_flow.engine.MidProcessAutomation.messageFlow(MidProcessAutomation.java:55)
at com.service_now.mid.probe.IPaaSActionProbe.probe(IPaaSActionProbe.java:101)
at com.service_now.mid.probe.AProbe.process(AProbe.java:104)
at com.service_now.mid.queue_worker.AWorker.runWorker(AWorker.java:122)
at com.service_now.mid.queue_worker.AWorkerThread.run(AWorkerThread.java:20)
at com.service_now.mid.threadpool.ResourceUserQueue$RunnableProxy.run(ResourceUserQueue.java:647)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Can someone please explain what this means ?
PS: I have changed the URI for privacy reasons
Thank you
11 REPLIES 11
Hi Ashutosh,
The request body looks like this -
{"from" : 0, "size" : 0, "query":{"bool":{"must":[{"match_phrase":{"message":"DELINK REQUEST RECEIVED"}}],"filter":{"bool":{"must":[{ "range":{ "@timestamp":{ "gte":"2020-12-03T08:42:46.8221590Z","lte":"2020-12-08T12:42:46.8221590Z"} } }]}}}}}'
This works for 2 our of 4 endpoints. Only fails for 2 out of them though.
HI,
Same methods or different? GET POST PUT?
In flow are you getting 500 or 400? Error code
Ashutosh
