Advanced Reference Qualifier for Assignment Groups
Chad R
My first post! I'm working on a Advanced reference qualifier that calls a script include based on a custom field on our incident form called u_restricted. The goal is if that is flagged true on the ticket then the reference qualifier that calls the script include will query a list of assignment groups that are for restricted tickets they also have the u_restricted field. Below is the code I have thus far and its failing dismally hoping some of your more well versed admins can lend me a hand. I'm about a year into my ServiceNow adventure so still learning the ropes. Appreciate any help!
Here is my dictionary override with the reference qualifier segment.
Here is the Script Include code:
function CNDTCheckRestrictedStatus()
	var assignment=[];
	var restricted = current.u_restricted;
	//return if the current restriction status
	if(restricted == false)
	var groups = new GlideRecord('sys_user_group');
	groups.addQuery('u_restricted', '=', 'true');
	groups.addQuery('active', '=', 'true');
	groups.query();
//query groups to return if the ticket is restricted
	while(groups.next())  {
			assignment.push(groups.getValue('name'));
			gs.log("DP: RefQual: " + assignment);
			return assignment;
Hi Chad,
update code as below; you need to have the return statement after the while loop ends
also in reference qualifier script update this; you need to let the query know which column the script include function is returning so accordingly it will filter the records
	var assignment=[];
	groups.query();
return 'nameIN' + assignment;
Elijah Aromola
Your code needs to resolve to a comma separated string like "group1, group2, group3", etc. Try the following:
function CNDTCheckRestrictedStatus() {
    var assignment = [];
    if (restricted == false)
    groups.query();
    while (groups.next()) {
        assignment.push(groups.sys_id);
        return assignment.toString();
Hi Elijah,
Thanks for the response I gave your script a try and got the following error in my logs:
Invalid query detected, please check logs for details [Unknown field null in table sys_user_group]
The subsequent logs are not much use.
Try this modification:
    groups.addEncodedQuery('u_restricted=true^active=true');
    groups.query();
    return 'sys_idIN' + assignment;
Hi Chad,
	var assignment=[];
	groups.query();
