Assigned to Field in Problem does not show any data
Arnab22
I am working on configuring our Problem Module. I am able to assign Problems to a Group, however when I click on "Assign To" the members show up as blank. I am able to use the same Group for Incidents and assign the Incident to an individual in that Group. Any advise will be greatly appreciated.
Arnab
Carl Fransen1
Hi - the new Madrid requires additional setup - the 'assigned to' field has a dictionary override for the problem tale where the reference specification require the 'problem_coordinator' role, as per below screenshot:
Hope this helps
Cheers
Carl.
Mike Allen
Check the dictionary override for the reference qualifier.  Looks like there is a reference qualifier in there that is stopping people from showing up, like maybe they need the problem management role, or something akin.
Carl Fransen1
Hope this helps
Cheers
Carl.
Thank You So much Carl, I assigned the problem roles to the users and they now show up.
Great stuff - glad I could help you with this.
