Assignment Group is not getting changed as per Record Producer
Chaisai
Kilo Expert
For a Scoped Application and Table in it i have created a Record producer and once the task gets created from the Record Producer it will be assigned to some group for this i have used in the script section of record producer
current.assignment_group = gs.getProperty('assignmentGroup.Example');
while this worked perfectly and as required in the DEV instance , when i moved entire record producer and export and imported Group to the UAT , for some reason it is not getting assigned as per the property and getting assigned to different group. I have checked the sys id s of groups in both instance and what not but could not figure out what is happening. Any help in this is much appreciated! Thanks.
Chaisai
Kilo Expert
Hi Everyone,
Thanks for your precious time and replies.
In my case there was both a business rule and workflow running on the Custome Table and changing the assignment group. Obviously i could not put set workflow to false to use. So i have tried with a before business rule and after tweaking a little bit with the order of the business rule i have achieved the functionality and this whole issue was because of the configuration differences between UAT and development instances.
Chaisai
Kilo Expert
Hi Everyone,
