Auto Insert of Required Approvers based on Affected CI Change Approval Group
sudhakar8
Change would like 'Required Approvals' to be added to a CMR automatically, based on the 'Change Approval Group' attribute on a CI (CI criteria: it is not Non-Operational) this would include CIs that are added to both the primary affected CI variable or or those included as part of the Affected CI TAB).
This is to be applied for both change types:  Normal and Emergency (i.e NOT to Standard changes)
//Add technical approvers to the change request when a new affected CI has been added.
var gr = new GlideRecord('change_request');
gr.addQuery('sys_id', current.task);
if(gr.next())
var change_grp = gr.u_technical_approvers_group.toString();
if (change_grp.indexOf(current.ci_item.u_change_approval_group) < 0)
gr.u_technical_approvers_group = change_grp + ',' + current.ci_item.u_change_approval_group;
//Force update to make sure the business rule to calculate risk and the change type will run when new affected CI has been added regardless the CR has
been updated with new approvals.
gr.setForceUpdate(true);
gr.update();
})(current, previous);
37 REPLIES 37
sudhakar8
Thanks for your help, I did but it is not removing from glidelist
create another BR on TASK_ci  after deletion checked
//Get the change request record of the affected CI getting deleted
var changeRequestGR = new GlideRecord('change_request');
changeRequestGR.addQuery('sys_id', current.task);
changeRequestGR.query();
if(changeRequestGR.next())
var tmp='';// Temporary variable to store value
var gr = new GlideRecord('task_ci');
gr.addQuery('task', current.task);
while(gr.next())
tmp+= ','+gr.ci_item.u_change_group; //+',' + tech_app;
var s=tmp;
var s2 = s.split(',');
var uniqueArray = new ArrayUtil().unique(s2);// Comparing array to eliminate duplicate values.
changeRequestGR.u_group=','+uniqueArray;
changeRequestGR.setForceUpdate(true);
changeRequestGR.update();
sudhakar8
I want to add approval group to "Required approval"when operational status is operational
sudhakar8
I have added the filter condition operational status is operational, it is working
cool bro
