Auto Insert of Required Approvers based on Affected CI Change Approval Group
sudhakar8
Change would like 'Required Approvals' to be added to a CMR automatically, based on the 'Change Approval Group' attribute on a CI (CI criteria: it is not Non-Operational) this would include CIs that are added to both the primary affected CI variable or or those included as part of the Affected CI TAB).
This is to be applied for both change types:  Normal and Emergency (i.e NOT to Standard changes)
//Add technical approvers to the change request when a new affected CI has been added.
var gr = new GlideRecord('change_request');
gr.addQuery('sys_id', current.task);
if(gr.next())
var change_grp = gr.u_technical_approvers_group.toString();
if (change_grp.indexOf(current.ci_item.u_change_approval_group) < 0)
gr.u_technical_approvers_group = change_grp + ',' + current.ci_item.u_change_approval_group;
//Force update to make sure the business rule to calculate risk and the change type will run when new affected CI has been added regardless the CR has
been updated with new approvals.
gr.setForceUpdate(true);
gr.update();
})(current, previous);
37 REPLIES 37
sudhakar8
Hi I have written one client script on "required approval(glide list field)"
When sub-category is "firewall" add Information approval group to required approval group
if (isLoading ) {
if(g_form.getValue('type') != 'standard') {
if(newValue =='Firewall Policy Addition')
g_form.setValue('u_manual_group_approvals','Information group');
due to this
1) When i delete any CI form affected CI it is clearing "Information group " from "required approval"
2) when we change sub-category it is clearing all the approval groups from "required approval" field
then you need to run the BR when category and subcategory changes. so that it will sync with your client script.
sudhakar8
we need to update delete BR
I am not sure abt your requirement. Try updating the BR and check.
sudhakar8
example :
