Best Practices for Locations and Work Spaces
k_ab
We're trying to track the specific work spaces. I.e, each office has multiple floors, and each floor has multiple work spaces.
Users or CIs could then be assigned to a work space;
Should each 'work space' be entered as an entry in the Location [cmn_location] table?
For example:
Americas
        United States
                  New York
                            New York City
                                      Office Building Name
                                                Floor 32
                                                          32-092
                                                          32-092
If office buildings are already in the location table, when would you use the Building [cmn_building] or Buildings [cmdb_ci_building_facility] tables? Would floor and work spaces be fields within these tables instead?
Any thoughts to help us understand the best practices would be great. Thanks in advance!
Ahmed Drar
Hi , How about creating a custom table for instance u_position , relate the table to location table so one location has multiple positions .I think the issue can be fixed by using location parent/child structure   and a custom table to store position data Americas -->Location         United States --> location                     New York --> location                             New York City                                         Office Building Name                                                 Floor 32 -->position                                                             32-092 -->position                                                             32-092 -->position
vkambham
Keith,
Adding work spaces to cmn_location table will make the the table very large and slow down location look ups on forms. The other disadvantage will be the space names are typically coded so usually users will not be able to provide it always. The pro will be that you have only one location field.
An alternate way would be to load the spaces in another table and   relate it to cmn_location. Then add a second field on forms   (we called it Location Details)   and make it optional.
-Venkatesh
