Caller populate based on Company
kun1
Hi team,
I have a requirement to create a reference qualifier to populate caller based on company. Suppose if we have a company ABC and in user table company mentioned as ABC but we have two more company suppose ABC_Rest and ABC_non_rest then also ABC member should be populated on caller field if we select any one of this.
Company is dynamic like ABC(ABC_rest and non_rest) or XYZ(XYZ_Rest or non_REST)
That i know we can make dependent.
lets suppose i have a caller A and in user table there company is XYZ then we make make it dependent but suppose i have selected XYz_Abc(company name starts with same but this XYZ_Abc is a subsidiary of XYZ). If CYZ_ABc selected as company then also in caller all member of XYZ company should be displayed @Ankur Bawiskar
Hi @Ankur Bawiskar , i hope you understand the requirement now
@kun1
then you need to handle it via advance ref qualifier and use script include.
subsidiary means is it a child? if yes then you can use parent field on company table to determine that.
What script did you start with and where are you stuck?
Hi @Ankur Bawiskar .
On caller field if company class is company then populate caller with A company other populate caller with the associate company . I hope this clear my point
@kun1
so what script did you start with and where are you stuck?
