05-13-2022 03:16 PM
Hello, I am trying to make the caller field appear red in list view on the incident table, when the caller has a vip flag set to true (on sys_user table). I currently have the vip flag on that field, but can't seem to change the font color of the caller's name to red. please help! 🙂
Incident Management
05-13-2022 06:48 PM
Is that what you initially wanted or did I misread what you wrote? If so, sorry about that.
Actually, after re-reading what you wrote...you said it both ways, thus the confusion was accidentally caused...
"Hello, I am trying to make the caller field appear red in list view on the incident table"
then you said: "but can't seem to change the font color of the caller's name to red"
My goal was to point you as detailed as I can to accomplish what you asked for. From here, it is hopeful you can try things out and learn, etc.
It's recommended to refer to documentation for guidance beyond what I've shared as that can answer your questions: https://docs.servicenow.com/en-US/bundle/sandiego-platform-administration/page/administer/navigation...
Inside the record, the caller's name is red there. So you could use the modern cell coloring for list view, which is a red dot and a bit calmer, then when they open the record, the name is in red in the caller reference field.
Otherwise, if you use list control for the respective table list, you can click "Omit links" and "Omit drill-down link" and then use color:red; in the style and that works for the font color...but then you disable all links in list view and that's not ideal.
05-14-2022 12:23 AM
Hello
You can achieve this by following the below steps:
1. Go to Incident Table, open the record and right click on the caller field and click on Configure Styles.
2. There will be OOB style for the VIP caller, but as per your requirements modify it to:
color : red
3. Go to the Incident Table List view and do a right click on the column and select Configure->List Control.
4. Another page opens, just check Omit Links and Omit Drill Down links to True.
Please see the below screenshot for your reference:
Do amrk this helpful, if my solution helped you 🙂
Visakha
