Client script is not working for specific users
Sriramachandra1
Hi Team,
i have created customer changes record producer for change req mgmnt
i have created a  catalog client script to load put some values
i have written alert to check that script is reachable or not
i found issue with some users and a pattern
if i create a user in sys_user table and assign company and " itil "and "snc internal role" --client script is working fine
when i'm creating user from core_copmany giving same roles was not able to access client script
note: Both users are having same roles same company
it  simple client script nothing complex
consider   only one line of code  alert("reacgeble load script");
can anyone help me overcome the issue
@Ankur Bawiskar @Sandeep Dutta @Mark Roethof
17 REPLIES 17
Ravi9
pls share ur actual code which is not working , we can work from there
client script
function onLoad() {
  //alert(g_form.getDisplayValue('company'));
	var company="Visteon 1";
	alert(company.includes('Visteon'));
	var ga =new GlideAjax('GetCompany');
	ga.addParam('sysparm_name','getDetails');
	ga.addParam('Company',g_form.getDisplayValue('company'));
	ga.getXML(getResponse);
	function getResponse(response)
		var answer =response.responseXML.documentElement.getAttribute("answer");
		alert(answer);
		if(answer!= null)
			g_form.clearOptions('please_select_the_customer_specific_change');
		g_form.addOption('please_select_the_customer_specific_change','','-- None--');
		g_form.addOption('please_select_the_customer_specific_change',answer,answer);
script include
var GetCompany = Class.create();
GetCompany.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	getDetails:function(){
		var company =this.getParameter('Company');
		var gr = new GlideRecord('question_choice');
		gr.addQuery('question','a17c310087c64110fc692f49cebb351a');
		while(gr.next())
			if(company.includes(gr.text))
					return gr.text;
    type: 'GetCompany'
Hello @Ankur Bawiskar
take a look at ac code
in above sysid is refers variable in record producer
so is the script include not getting called for that user?
what came in alert for answer?
it is not going into client script for that users
for testing i have given this alert
it is reachable and working for first type of users and not working for second type of users
